Mysterious Symbol
15 replies · 3,421 views · Started 22 November 2004
Hello everyone, i have just purchased a Sendo X on Vodafone from eBay (got a pretty good deal) and i cant figure out what this P1 icon means. It is located next the the signal bar.
Im sure i didnt see it in the instructions. If its there, im sorry for wasting your time 😊
Hi Omega,
The symbol refers to the profile you have selected, i.e. general, silent, games
Makes sense 😊
Thanks for making me feel slighly dumb :laugh:
Seriously though, thanks 😊
omegax wrote:Makes sense 😊
Thanks for asking that question... I was just about to ask it myself... Now, you're the one that looks dumb, instead of me!
Oh... Too late! 😊
Seriously, thanks for asking the question. It's not the most intuitive of icons, but it is a useful one and I'm glad that I now know why on earth it's there!
Dave
Haha, no probs, I didn't know what the symbol meant either untill somebody else asked about it a few months ago in another post.
I did try searching but didnt find anything. I dont like being the person that asks the same question for about the millionth time 😊
One more question though, if you dont mind. Have you ever tried bluejacking with this phone? I have tried through the contacts screen with little luck, so do i have to use something like Mobiluck?
Cheers 😊
Mobiluck caused problems with calls not being received for me...however, it may be worth another try once the 60D firmware is available for everyone...I'll do some testing once my handset is updated and let you know...
Ive been keeping an eye out for the update. Will it be released this week for us brits you think? At the moment i have version "X1.63.1.2, Release IG, 4-Sep-2004"
Yes, I'm 99% certain it will be out this week. Plinkykev will be able to tell you for definite, but he did say at the end of last week "within the next few days", and I know there are other things he's pushing to get sorted out this week as well 😉
Well i look forward to the further stability 😊 I have noticed a few glitches here and there, but nothing major.
Im hoping to get a larger capacity MMC/SD card soon as i only have a 64mb one at the moment. I take it the Sendo is compatible with all brands?
stuclark wrote:Mobiluck caused problems with calls not being received for me...however, it may be worth another try once the 60D firmware is available for everyone...I'll do some testing once my handset is updated and let you know...
I�m trying just now Mobiluck with the 60D 😊
I found people via BT but im not able to send them nothing.
Doing the usual bluejack it works.
With the mobiluck active.... I�m able to receive calls
morph - that's one move in the right direction then - on 50C and 50F, Mobiluck does that call blocking thing, where only every other call gets through.
I used to be able to send things to people using Mobiluck - maybe the reason you're having problems is actually down to the receiving phones asking for confirmation before accepting the transfer... if so, then bluetooth security is working for once 😉
After playing with Mobiluck, i found it works fine, but the software just isnt too good. Its ok, but, like meetingpoint), its much better to just bluejack the normal ways 😊
Mobiluck have updated their software so maybe it works a little bit better, make sure its mobiluck.co.uk u go to and even tho it says version 2.15 its actually version 2.20 .com still has .15 so us brits are treated nicely once again :icon14:
