GNUbox for on 6630 (or old ver backward compatibility)?
2 replies · 13,451 views · Started 23 November 2004
JoKerTheFirst wrote:Hello there,
I'll go direct to the point; I want to share my internet connection on the PC via bluetooth to make my 6630 surf on the internet....i need GNUbox on the cellphone in order to achieve it.
Does anybody know if there's a 6630 verion of GNUbox?
...is the 6600 verion compatible with 6630?
best regards,
JoKer
I doubt the 6600 version would be compatible with the 6630. But you probably have tried this anyway 😊
There is quite a number of users out there wanting gnubox on their 6630. As I have already done the tedious task of porting GnuBox to an other phone (that was the SonyEricsson P910, see the result here: http://gnubox.dnsalias.org/gnubox/) I could probably do it again with a lesser effort.
Unfortunately I have no 6630 😞
Thus if you can and are willing to help me in testing, then we could do the port together. I write the code, give you a .SIS, tell you what to do, and you tell me what happened 😉 Then again, I fix or try to fix, you test. Until it works (or we give up).
Shall I help you?
-xan-
