N-gage Qd Mmc Type
7 replies · 2,235 views · Started 23 November 2004
I just got a ngage qd and i was planning to use the mmc from my 6600.
but it looks like i cant inserted it.
does the qd use reduced sized MMC??
plese help
thanks for reply.
i am using a TEC MMC 512MB on my 6600 and was planning to use that one the QD and use another on the 6600.
The problem is when i try to insert it, it looks impossible and gets stuck if i push it a lot.
also the slot inside looks different and made for smaller cards.
Is there something wrong or i am blind?
Standard MMC cards should fit without any special effort/force. Is it perhaps thicker than the standard really allows for (like SD cards, which are of the same form-factor, but thicker)? Is the slot OK (nothing stuck inside it)?
thats what i was thinking about.I bought the ngage from Ebay.
Its in new condition with all extras.When i look inside the slot it looks empty.
I think i can even see the pins.
I pushed it before and then i had to grab it in order ro bring it out.
And the cards goes until far inside the slot, which looks impossible afterwards to take it out.IS this normal?
The card is a TEC 512MB MMC widely used from many people.
actually i got it working.
the small mmc that came with my 6600 is smaller.
the tec is thicker than the others....
i guess i wont taking it out all the time...
