MSI Blutooth key and any motherboards
2 replies · 2,207 views · Started 13 October 2002
Hi people,
Will the MSI Bluetooth Key work with any motherboard or does it have to be as it says on the Komplett website
"MSI Bluetooth Key USB for 845E MAX2-BLR
and KT3 Ultra2-BR, USB "
Coz maybe this is the main problem that peple are having and its not just a software problem but the fact that some people have compatible motherboards and some dont hence one person getting it to work with the same operating system as another person who cant get it to work.
so is it motherboard related?
Yes very much looks like it! I found out the hard way! IR does not work for my but BT does where in other cases BT does not work and IR does. However, most ppl dont face problems with the BT software itsleft but more with PC Suite, which might indicate that it is a software problem as well!
I use MSI bluetooth with ASUS motherboard and it work fine. The BT run on both Windows XP and Windows Me. I also test it with my Fujitsu notebook. It all works.
