Anubody know the range of the ir port?
1 replies · 1,850 views · Started 24 November 2004
I like teh look of total itremote and after emailing psiloc, they tell me a sendo x version is in the works.
But do u lot think it will be any good? I have tried things like this with my old palm and the ir range was like 1/2 meter! Do you think the sendo x is the same? It would make my day to find out the range of the ir is more like 3 meters. If not, ten why have ir software?
I'd be weary of applications from Psilloc on the X - I've had nothing but trouble, and their support department haven't exactly been helpful... 😞
