I seem to be having a problem with Psiloc's Hotspot Finder, when I try and run the program I'm getting the error message: Note: System: Unable to find the specified Object.
I've ran it fine once, but now I keep getting this error message, i've uninstalled and reinstalled quite a few times, but i'm getting the same message everytime.
I've emailed Psiloc, but haven't had a response yet...anyone have any ideas?
Possible other causes/suggestions:
- Have you tried a reset (taking the battery out)?
- Is Wlan already in use by the webbrowser or something?
Delta737 wrote:Possible other causes/suggestions:
Yes tried both of those, going to format for a quick solution. 😡
I have noticed when you run the hotspot software and it finds a new hotspot I then close the Hotspot program and try to use the web browser to connect to that wireless network that was found and every time I cannot connect , it like jams up the web browser it is only when you remove the battery that you can use the web browser again.
Mine was a different error, which has now been fixed by upgrading to a later version, which should be available in the near future (It's Symbian Signed)
