This is the story...
I had 7650 till yesterday and my beautytfull 450 contacts in it.
I did the backup using PC suite and than manualy copied Contacts.cdb to another safe place.
I bought 6600 and I'm more than happy with it but there is no way I can restore my old adress book 😞
Nokia 6600 does not have Flight mode and that is the only mode in which i could overwrite the Contact.cdb 😞
Backups that are done from new pc suite are difeerent than the old ones and are unreadable and not understandable to me 😞
Can anyone help?
I even would re enter it by hand but i need something to make contacts.cdb readable.... when i open it in txt editor it can't be done.
Contact transfering problem. Urgent :(
Doesn't Psiloc System Tools work on the 6600?If you still have access to your 7650 synchronize it against Outlook and then sync outlook with your 6600 or you can try Contacts Transfer from http://personal.inet.fi/private/riihimaki/s60/ or SmartvCard from www.symbianware.com
System tools work, but flight mode doesn't.
Cant get to my old 7650.. it is in another town :frown:
p.s. Tried that finland site and aplicanton yesterday... not working... and smartVCard i think cant read contact.cdb
😮 :frown: :frown: :frown: 😮 nothing?
