hey pplz , atlast i got a second hand n gage in good condition with all accessories.i am having a problem in my n gage..i get distortion or crackling sound from the loudspeaker whenever sound is played at a higher volume , when i play a good quality sound file like mp3, the crackling sound gets reduced.Is my loudspeaker damaged? Is it normal?or does this happen with all n gage users?Should i hard reset my n gage? which is the best quality ringtone settings for .wav files or mp3 files?
thanks in advance
Tariq
Hey yeah i got the same problem one of the major effects is keeping your volume on high while playing long segments of sound wavs (Like music) n-gage wasnt meant to do that and you'll blow out your speakers. Dont worry its not permanent but if you are listenining to music use headphones (Specifically designed for n-gage) Usually crackeling can be stopped by turning of your n-gage for 5 minutes and turning it back on or just lowering the sound for a while.
I get a crackling sound in my speaker whenever the treble part comes in . When i blow air in the loudspeaker output it gets normal.then again it starts up.i took my n gage to a mobile shop and i told him about the speaker problem he told that the speaker is damaged.he changed the speaker and installed a new speaker but the problem was that the volume of speaker was low. he told me that there is no special speakers for n gage ? is that true? i told him to put back the original. should i take it to nokia centre. i dont have warranty.how much will they charge?please help me !!!
Does anyone has a solution to :frown: my problem ???????
tariq_87 wrote:Does anyone has a solution to :frown: my problem ???????
hi i am also from jeddah so u bought second hand there is no problem in your speaker if u are playing mp3 files then check the bitrate or may b u cant play the sound at the fullest volume its like turning the computer's speaker to the highest volume u try that there always will be a cracking sound anyways can u tell whether in saudi arabia qd covers are avail;able???will wait for ur respnse
just sef wrote:hi i am also from jeddah so u bought second hand there is no problem in your speaker if u are playing mp3 files then check the bitrate or may b u cant play the sound at the fullest volume its like turning the computer's speaker to the highest volume u try that there always will be a cracking sound anyways can u tell whether in saudi arabia qd covers are avail;able???will wait for ur respnse
hey , so r u from india?? well actually when i play default tones still i get slight distortion , i think my speaker is damaged, i will be taking it to nokia service center.well i am not sure about qd covers , why dont u go to falasteen street , u may get it there.so what do u do ???
My n gage sounds clear. Im selling mine for 80 dollars u may pick up or i will ship
i think your speakers are busted. how do i hard reset my n-gage?
busted speaker is a HARDWARE problem .....u whont do nothing by formating your phone...just chill..its normal...
the best solution for this is to keep the volume at a resonable loudness so the speaker would sound great and no distortion...and if u know woh to use cooledit pro low the bass-medium frequencies(from 3000Khz to 10000Khz)and increase by a small factor the high freq(16000-30000Khz) u might get some good results at a high volume(of course if u will use that mp3 only as a ring tone)
best mp3 quality i've used is 320 kb/s but ofcourse that tahes a lot of space..still it works fine with 128kb/s mp3's
btw the ngage classic original headphones suck big time...wery low bass and volume...i modified my head set with a pair of panasonic head phones and now the sound quality rocks big time....
so...with ngage u can do almoast anything....u just have to have ideeas
regards
If crackeling continues, look inside if a screw is loose.. I had to put little glue in the hole and tighten the screw, no more crackeling 😊
