9500 divert calls not working ?
6 replies · 3,127 views · Started 24 November 2004
Hi all,
I am trying to divert unsanswered calls to a.n.other phone number,
I keep getting the following message
"Telephone: unknown parameters in the service request"
any body got this error message too,
Cheers
Matt
Depends on the number, mine works fine to another vodafone and landline numbers. It will not work on voicemail box number though.
Maybe im doing something wrong,
What procedure do you use to divert your calls bud,
Also what is your firmware version
*#0000#
V 04.44(01(
27-10-2004
RA-2
(c) Nokia
From the front, go to setting, call setting, chose divert if unanswered type phone number and select delay then done.
Same firmware as yours
I already tried that bud,
I just tried it again to double make sure and it comes up with
"request not completed"
Full signal strength
I think I have found the culprit.
The ruddy simcard.
Just put the sim into another phone and tried to divert and it comes up with same error.
