It would seem that anything that accesses the camera in any way refuses to work (I mean things like games that access the camera, photo editors etc). Also, some audio software (lie detector, Heresy etc).
Does anybody know if this is an issue due to the platform, or is it a bug that will be fixed in the next firmware update? If so, does anybody know what the latest firmware version is and whether I need to go to 'specialist' Nokia service centres (as with the 9210)?
Thanks in advance.
Those applications probably must be updated to work with updated Series 60 camera APIs (Application Programming Interfaces), I'd say. Contact the software vendor (in case they already have an update ready).
N/A wrote:Those applications probably must be updated to work with updated Series 60 camera APIs (Application Programming Interfaces), I'd say. Contact the software vendor (in case they already have an update ready).
i have the same problem 😞(((((( facestore snap (requires video) do not work as all the software that require video use 😞((( all the software from 6600 and 7610 works on the 6260 so i would say that nokia fucked up the soft (?)...
i hope they will fix it asap
Semtex wrote:i have the same problem 😞(((((( facestore snap (requires video) do not work as all the software that require video use 😞((( all the software from 6600 and 7610 works on the 6260 so i would say that nokia fucked up the soft (?)...i hope they will fix it asap
Photobase works (in case you're looking for something)
