P910i won't sync with Lotus Notes Calendar
1 replies · 7,412 views · Started 25 November 2004
I have my address book sync'd OK, but I cannot get my Calendar to sync.
My XP Internet Options does not have Lotus Notes Calendar as an option in the dropdown, only Outlook. I've been told that this is a problem, but have no idea how to make my Lotus Notes Calendar the system default.
When the sync starts, it picks up my calendar file and analyses it, but does not tell my why it fails.... and I cannot find a log file anywhere.
What do I need to do so that I can get my lotus notes calendar sync'd?
thanks...
By deleting ALL entries in my calendar then performing a sync everything worked fine.
I then added back the calendar entries that I had an email invitation for and synced again.... successfully this time.
I have found that if you have ANY time conflicts in your calendar that the sync does not work... nor does it give any idea of why or log to a file.
Sony have been totally useless on this problem and blame it on Lotus Notes, which is completely wrong as the prolem clearly lies in their software.
