Network Connections - Confused
3 replies · 2,876 views · Started 25 November 2004
Gents,
I managed to connect to my wlan last night and was happily surfing OR reading emails, but when I was connected to my emails, and then tried to surf the web, it started using GPRS because the primary WLAN connection was already taken - so Email was over WLAN, and Web was over GPRS...
What have I missed?? Isn't there a way to let the "whole" phone use one Internet connection, instead of one application "hogging" one connection...?!
Oh, and I admit, I've not read the whole manual yet (just used it as a reference), so if it's in there, I'm more than happy to read about it...
.. But if someone knows I'd be happy to get an answer.
Thanks!
Have a look here for setting your preference for connections for email:
Menu>Account Settings>General Tab (for your email account)>Internet Access (bottom option)>Your WLAN
jah wrote:Have a look here for setting your preference for connections for email:
That's how I got it set, for both of my currently installed email accounts, but....
I first connect one email account and it establishes WLAN connectiong
Then I connect the 2nd email account and it tries to establish the same WLAN connection (which it reuses).
Then I open up Web, and it tries to connect to the WLAN, but fails, and falls back to using GPRS....
Annoying... 😞
TheJoker wrote:That's how I got it set, for both of my currently installed email accounts, but....
Annoying... 😞
I actually rang Nokia Tech support about this 😮 and have experimented agressively and have now got a series of settigns that I find work.
For some reson when you are connected to the web via a home gateway you cannot use email simultaneously ont he same connection. If you use a commercial hot spot this problem goes away (do nto ask em hwo the device cn tell the difference but it does.)
I have setup four remote mail accounts and some local folders in the email application one is called mailbox_GPRS and another mailbox_WiFi_Home and another mailbox_WiFi_Public and finally a mailbox_CSD.
Each of these accounts is pointing to the same mail server and when I created each one I specified a specific internet connection type under the General tab of the account settings for each account and I turned off all automatic settings under the Roaming tab.
I have a mailbox_wifi_home account because at home I cannot use DHCP (see another post re IP V6 interferring with IPV4) and so have a specific access point setting with a fixed IP address.
I then created several folders where I store emails I want to keep work on etc and I use which ever account is appropriate to download the emails and then store the ones I need to work on and delete the rest.
It works very reliably this way whereas the automatic systems have not been so much fun for me.
Incidently when I want to do email I switch to web hit Control - U switch back to message then hit retireve and then switch back to web and continue surfing.
All the Best :icon14:
Bill
