Hi. I was starting the BT connection via key shortcut, but the 9500 send a window with the message "Bluetooth Error".
Do you have any ideas?
Is there a way to do a soft reset?
Thank you
Bluetooth Error
You can do a soft reset by taking the battery out
fuoriporta wrote:Hi. I was starting the BT connection via key shortcut, but the 9500 send a window with the message "Bluetooth Error".
Thank you
You can download 'reboot ' from most of the good site like handago 😊
