App. Closed Maillnit - phone is completely stuck!
1 replies · 3,934 views · Started 25 November 2004
1) I reset my phone using Menu->Tools->Settings->General->Orig. phone settings. Phone was working till then.
2) Switched off phone and used SIM card in another phone. Switched it on, received an "App. Closed Startup" error. Reset phone using *#7370#.
3)After entering Time and Date, received an "App. Closed Maillnit" error. Cannot open Menu, app. on the softkeys, joystick, etc. Receive a "System error" message when try to open these images.
4)Phone seems to be running properly in safe mode only though.
Any ideas how to make the phone work properly?!?!?!?!?!?!
rohitkhannak wrote:1) I reset my phone using Menu->Tools->Settings->General->Orig. phone settings. Phone was working till then.
Sounds like your MMC might be corrupted. Try turning off your phone, installing new MMC, then turning back on. If you're lucky everything will work fine.
