9500 screens formats
6 replies · 3,622 views · Started 26 November 2004
Hi. do you know what's the dimensions of internal and external displays in pixel?
just to build my own wallpapers
fuoriporta wrote:Hi. do you know what's the dimensions of internal and external displays in pixel?
amf is actually right. True, the physical dimensions of the LCDs are for the external screen 128x128 and for the internal screen 640x200 but the wallpaper size as you can see does not cover the entire area of the internal screen. The dimensions of the wallpapers are for the external screen 128x128 and for the internal screen 463x194. You could verify this if you used the automatic wallpaper creator, "Edit Images", in Nokia PC Suite. (Naturally a software like photoshop will give you faster and better results using "crop", and setting dimensions on crop resizing.)
To add something I just noticed. The dimensions amf wrote I think are the dimensions of the 9210's wallpaper size. Although both 9210 and 9500 have an LCD that is 640x200, the actual size of the wallpaper is not the same between the two.
