Hi. anyone use a powerbook configured to share the internet connection via wi-fi to connect the 9500? what's the exact procedure to follow? it doesn't work for me, even if powerbook is visible to 9500...
Wi-Fi with Apple Powerbook - internet sharing
fuoriporta wrote:Hi. anyone use a powerbook configured to share the internet connection via wi-fi to connect the 9500? what's the exact procedure to follow? it doesn't work for me, even if powerbook is visible to 9500...
what router are you using????
g or b??
I don't get it. If you have you Powerbook connected to WIFI, why not also the 9500? Why the 9500 VIA the Powerbook?
Huib
Huib van den Oever wrote:I don't get it. If you have you Powerbook connected to WIFI, why not also the 9500? Why the 9500 VIA the Powerbook?Huib
I'm guessing his powerbook is plugged into the net connection, and he wants to use the powerbook as a router.
ventmore wrote:I'm guessing his powerbook is plugged into the net connection, and he wants to use the powerbook as a router.
Exactly... PB plugged with a ISDN modem (soon with HDSL 2Mbit) and configured as router.
gggggg
