Does anyone know why I cant get Bemused v1.73 to work on my Nokia 6600?
It says it for series 60 but after I've installed it it says cant connect to PC, It engages the bluetooth and my computer shows it as connected but the the 'can't connnect to PC' appears on the Phone and It stops trying.
Cheers in advance,
Mike
the first time u use Bemused, u shout do this:
- pair the phone with Pc and allow file transfer on both side.
- if u got XP SP2 do not install the BT-SW, only put the stick in USB and use the MI driver.
- enter msconfig and unmark the 2 Pc-suite entrys.
- open the first time bemused on Pc and connect it with the active serial port.
(enter the com port, and put the button connect:
the port number u can find @ options in BT: it is the incomming port)
then open bemused on S60 and go to
options/.../connect 2 Pc: automatic
like this it shout work, somethimes u must reconnect it,
but all in all, like that it works on my system like a charm.
hope this help u out, and sorry my bad english.
S�mi
