HELP ME - I installed a theme and a SIS file to change icons with the theme. After that, my P910 doen't boot up correctly - after entering the pin, the S/E looks comes up and stays....I removed the battery... nothing changed.... Is there a way to format or hard reset everything WITHOUT entering into the MENU?????
Thank you!
torsten 😡
It is Symbian XP EVolution icons by UM
I also had the same problem.
Turn on the phone without Simcard.
Then go to hidden menu (turn jog dial up * jog dial down jog dial down * jog dial down *).The menu will pop-up.Go to Service Function.You will be asked wheather to format the disk or not.Format the the Internal (C: Disk You will loose all data ).
If you are not able to go to Hidden Menu Then take your phone to SE Service Center.
Indian_Dawg wrote:It is Symbian XP EVolution icons by UMI also had the same problem.
does this success ?? I also had same problem ? plis help my poor fone ! Thanks a lot
