To enable the Developer Menu on File Manager (SX1), do the following:
1 - Download the following programs:
GetIMSI:
http://sx1.webhost.ru/upload/Soft%204%20mobile/other/getimsi.exe
Siemens Service Code Generator (one of those, they're all the same):
http://downloads.gsm-technology.com/program/Siemens%20Service%20Code%20Generator%20v1.01.zip
http://www.siemens-java.com/tutorials/Net-Monitor/monitor.zip
http://www.siemensiak.pl/download/sscg.zip
2 - Copy "GetIMSI" to your phone (memory or MMC) and run it. It'll show the IMSI code of your SIM card. Copy it down.
3 - Run "Siemens Service Code Generator", and select "Level - Code 1". After pasting the IMSI code, press "Make Code".
4 - Finally, create an entry in your SIM phonebook on the very *LAST* entry. If your SIM card can store 100 contacts, you must create an entry with the generated code in the phone number and any name on the 100th field.
Now, if you go to the "File Manager" it should appear like in the screenshots attached.
[QUOTE=marcio.f]To enable the Developer Menu on File Manager (SX1), do the following:
GetIMSI:
Now, if you go to the "File Manager" it should appear like in the screenshots attached.[/QUOT
hi,
i tried the 1st link but it wa secured and ask somthin like password do y have any solutions ,i tried to subscribe in it but i dont know where to do that. plz help
hi,
Hi, i really don't know what happened to the site, because when i downloaded it a few weeks ago it didn't ask for no pw, so here it is.
Also, don't forget that you can enter in another developer menu by pressing # on the main menu.
getimsi.zip (1 KB)
