I have a lot of questions about GPS for the N-Gage.
1.Do I need any extra hardware or just software?
2.What decent GPS software is there for the N-Gage?
3.If I need any hardware, what type is it and what models would you suggest?
Thanks. 😊 😉
Thanks. 😊 😉
1. There is no GPS hardware so you do need a Bluetooth GPS module (EMTAC, Pretec, Rikaline or other).
2. WayFinder (http://www.wayfinder.com/) or TomTom MOBILE (http://www.tomtom.com/), for example.
3. See #1.
Ok, thank you for your response.
About Q1, How do you mean GPS module?
Thanks.
merther02 wrote:Ok, thank you for your response.About Q1, How do you mean GPS module?
Thanks.
Its is a small reciever for the GPS satelite signals, this would then relay the information to your NGage via bluetooth.
Something along the lines of this: /www.rikaline.com/bluetooth_gps.htm
Ok, anything cheaper than that though?
Thanks again.
