Sync. with free e-mail software. pls help
9 replies · 2,854 views · Started 14 October 2002
I need help regarding this issue.
As I use my 9210 for bussines purposes, I discovered that I am not allowed to use e-mail client like MicroSuks$ Outlook.
Do you have any clue haw can I sync my contacts and e-mails with other free software?
Also for Calendar I need sync.
Best Regards,
Me, Myseslf and I
I switched to outlook express but is no way to do it I think.
I will switc to any e-mail client freeware that wil work with my 9210.
Thank you in advance
FYI -- MS-Outlook Express is not compatible with 9210's PC Suite... only pure MS-Outlook... (not express) 😉
I still have problems with finding sync software to fit with my needs.
Are`t anybody having an ideea how to :
Syncronize e-mails with free pc clients
Syncronize calendar with PC with free software
Sync contacts with my Outlook express or other free software
Sync my N9210 contacts with PC like I used with 9110? From this point of view 9110 software was better. I could edit my contacts from there and after that upload them on my nokia device.
Thank you
PCSuite is one crappy software product, so I'd be surprised if it worked with something else. (Hell, it doesn't even work well with Outlook). Supposedly, it's capable of using SyncML, which should give you a lot more flexibility. I'd look into bypassing PCSuite altogether.
-MB
I sync with thle ooe PC for contacts, i got a lot of e-mails I need to handle out of office, i use calendar in comunicator and Computer, A lot of stuff.
Now i solved upgradibg to outlook.
10x
