Getting P800 or P900 software wokring?
2 replies · 2,492 views · Started 28 November 2004
Hey anyone have any tips in being able to get P800 or P900 apps working on a a1000, some games and apps do but probly only about 5% that I've tried so far?
You need P800ProductID.sis (search in these forums for a link)... copy it to your SD card, but DO NOT RUN IT. You can then copy P800 sis files to your phone and install them from there (do not install using the desktop suite - it will chimp)
alainmoran wrote:You need P800ProductID.sis (search in these forums for a link)... copy it to your SD card, but DO NOT RUN IT. You can then copy P800 sis files to your phone and install them from there (do not install using the desktop suite - it will chimp)
Sorry, I can't find the file P800ProductID.sis in here, could you pls. post the link, thanks. BTW, does it mean after installing this file, other P800 or P900 software will work (i do understand not in full functionality) including common software like Handy Day 2004? Tks.
