Hi Guys
I am trying to get theme editor to work I am on xp.
The software works ie it starts up and I can put images in but when I try and save the finished theme it says theme created but if I open the theme in Theme Studio nothing has been changed.I also put it on my 6600 but there was not any of my images on.
cheers
Theme Editor
Hi Porche,
You need to click 'save' after each image you insert and then save and create the sis file.
Do your images show up in the preview?
Hi elton
The images do show.
Say on the menu I click on the blank space were the size is (176 x 144) then load an image then the image appears.I have been doing a few different menus before saving.
Cheers
