Since the last 2 days, I am facing a strange problem. Am unable to download attachments from my POP mail using my GPRS setting. I have not changed anything on that. My WAP over GPRS works fine, and I am also able to download attachments using the GSM Data connection from the same POP mail!
Anyone seen this problem before? Any suggestions?? Thanks.
I am still facing the problem...the headers are shown ok from my POP mail. However, when I try to retrieve any message, it says retrieving mail and just sits there!
HELP PLEASE !!! :cry:
Try another mailbox and see if it works!
Hi MaleBuffy,
I have tried that with the same result! I created a HOTPOP account and tested this.....Thanks for your inputs...
Did you contact your Network provider? It seems to me that for some reason your GPRS account acts only as a GPRS WAP account, meaning no email attachements since they limit the max size of files that can be received! Contact them and ask them if it is possible and/or what has changed!
Yes, this sounds like a possibility... 😊 I will contact them pronto! Thanks a ton (and hope that resolves my issue!!)
