Nokia 6600 + Outlook 2003 "un-synched"
3 replies · 2,992 views · Started 29 November 2004
I have been synching my 6600 with Outlook 2000 for the better part of a year now. Last week my company upgraded to Outlook 2003. It turns out that the 6600 PC Suite does not support Outlook 2003.
I called Nokia and they said that they have no plans to re-write the 6600 PC suite to support Outlook 2003. However they suggested buying a 6620 because it uses PC Suite 6.4 which does support Outlook 2003.
Has anyone else run into this?
If so, is there any way to trick the PC Suite 6.4 to recognize a 6600?
There is no way to make PC Suite 6.4 to recognize a 6600.
However, I should think Outlook 2003 is compatible enough for the 6600 PC Suite to work. Did you try?
I did try it and contacts works but not calander. Nokia verified that the 6600 PC Suite will not support Outlook 2003 (Other than contacts) and there are no plans to make a future release of Nokia 6600 PC Suite either.
