Camera Delay
3 replies · 2,039 views · Started 29 November 2004
Sorry this is quite hard to explain but here goes -
Why is it when i take a photo, the image that saves is different to the one that was there on the screen before it had saved?
Like i'll press capture an image will be displayed then seconds later it saves it and the image seems blurred.
When u Capture a Image it Take 2 -4 Sec to Capture
But if you Select the Low Quality then it take less time.
You have to stick the camera for 2to 4 sec when u capture a image.
When u capture Keep your camera there only till u see Saving image in the top center.
hey try and keep ur camera as still as possible and dont move it even after the snap sound is there.. jus keep it there and u'l notice that the picture comes out okay
