OPL editor on the 9210
4 replies · 1,734 views · Started 01 December 2004
I'm using the OPL editor on the 9210 to create programs (just started, and working on the train) but it's awkward because the lines are double spaced - given the small screen it shows only eight lines of actual code. Is this a feature of the editor, or have I inherited some double line endings ? It seems to be the same for code entered fresh or downloaded from the PC/email. I've tried changing font types/sizes but no luck so far. Any help here would be appreciated...
I use System Font, 8pt, at the minimum zoom setting, which gets about 10-12 lines on the screen. Hope that helps.
yes, thanks, that's better - from 8 lines to 10; but is this double spacing normal ? It seems to be a bit of a waste of scarce screen resource. Is the source code available for the OPL Editor ?
