I have recently had Windows Service Pack 1 installed on my PC and ever since this has happened i am no longer able to sync my phone! It comes up with 2 warnings as follows:
1)
SyncML Server information.
The SyncML Client has not sent any Authentication Credentials.
Possible Solution
Check that the SyncML Client is sending your authentication details and that they are correct, then restart the Synchronisation.
2)
The SyncML Server was unable to send a complete SyncML Package to the SyncML Client.
Possible Solution
Check the connection between the SyncML Client and the SyncML Server, then restart Synchronisation.
Can anyone help?
Regards
Dom
P.S. I am using Nokia Sync version 6.4.8
