Why is it that i can't keep the keys locked in brows mode. the backlight on of the display will always starts after 2 minutes, and the key locks will desipappear.
This doesn't ahpens otherwise....
Im I the only one having this problem???
/Jean
6260 in Browser mode problem!
to activate keylock in browser mode, simply press the left selection key followed by the menu key...
HTH.. 😊
Or a short press with the power key, and then select the lock option from the list. (You can traverse the list by repeated short presses of the power key, and when you reach the option you wish to use, do a long press. That way you can do it using a single key.)
I have tryed that but after 2-3 minutes the display will start again....
Strange
Have you got any fancy screensaver software installed?
Nope, but I uninstalled wayfinder and the fax program that came as test apps and that did it 😊
/Thanxs guys
