i can't find any OPTION KEY on the phone..
anybody could help??
since it's used to save online content to ur internal memory..
where is the OPTION KEY described
The key on the upper right side of the phone is Option key.
I just can't get it.What do you mean ?
There is no way to even get on the web with flip closed. So I don't get what you mean either. Are you sure we're talking about a P900/910 here?
Even with flip opened you can still press the option key on it (of course if you have flip on the phone and not using virtual one 😊)
However it will do the same as tapping on Internet menu in the browser. And yes, in the internal browser in P900 you can save the page contents into internal cache memory, I have one page saved like this and I can access it when there is no network (for instance in the Tube). I use this page to send texts from Internet, so I can type all text message using a cached version of the page and only send it when I will have network again (for instance on the Tube's station).
I don't know if it answers the question, anyway.
thanx for the answers..
bascially i was just trying to perform a right click on the browser...
i thought pressing the option key would do...
looks like nothing happened when i press that...
i have to click and hold onto the link in order to trigger the extra menu...
