Hello,
I'm looking for a tool which provides me the hability to trace running
processes in Symbian OS. Does anybody know something about this? In case
it doesn't exists, would it be a way to do it?
Kind Regards,
David
Hello,
Kind Regards,
David
TaskSpy, for example: http://www.pushl.com/
What do you need to trace? heap usage? if so, try Devman.
Wonderstuff wrote:What do you need to trace? heap usage? if so, try Devman.
I need to monitor syscalls made by running processes to know what are they exactly doing. The idea is to develope a kind of intruder detector.
I'll check Devman.
Thanks a lot!
David
