help me plz i can not connect my n-gage to my comput i hav try every thing but i can not connect it still it dos not show my n-gage drive it show nothing i put my usb port and evry thing in and still no luck so plz can eny one help me plzzzzzzzzzzzzzzzzzzzzz i am begging on my nez
n-gage connecting to ur pc
Does the N-Gage have a writable memory card (MMC) inserted? The USB cable connectivity just makes the memory card visible to a PC, but if there is no card, nothing will happen.
i have a trouble with the usb, the usb recognize my phone, appears the icon with the arrow, but cant assign a letter to the drive (n-gage) , but a while this works, suddenly this doesnt work more.
the only solution i haved (dramatic) its format pc with the n.gage connected when ure formating.
if someone haver other solution please help me
Hi, maybe ur mmc is corrupt. Try this one:
Corrupted MMC fix
Necessary tools:
- Corrupted MMC
- 7tools partition manager (get it here , the demo version is capable of carrying out this task)
- Pair of hands
- little brain but not necessary
lets do it
Part one
Put your MMC into your card reader, select the MMC
If your partition is corrupted you will see several invalid partions in red in the left hand pane (MMC drive section)
Right click each of these and left click delete.
Click apply (top left button)
You should be left with a single free unit on your MMC drive. Now right click that unit and select create primary partition. Go with the defaults which should be FAT16 and click on apply.
Exit and put your card back into your N-Gage. If you find that the MMC card still does not mount via the USB cable (That is if it was mounting prior to corruption). Unplug the cable and put your MMC card back into your card reader.
Part two
Start the 7tools and select the MMC again.
In the right hand pain you will see a column that says Active (it will probably be set to "no"😉 click this and set it to yes (That take a few MB of your MMC but it makes it an active bootable drive partition), click apply
Put the MMC back into your N-Gage and format it via tools-memory-[options]-format mem card.
You will notice that the card is a couple of MB down on it original size but it will now be fully bootable and functional via the USB cable again.
Keep in mind:
If u formatting MMC card trough windows u could fuck it up if you format in any other partition than FAT, no other partitions like NTFS, FAT32, don�t work!
Thats it, astalavista bay
Hope this help
Cheers
Wirelessly posted (N-gage Original: NokiaN-Gage/1.0 SymbianOS/6.1 Series60/1.2 Profile/MIDP-1.0 Configuration/CLDC-1.0 UP.Link/5.1.1.3)
In win 98, u ave to add it as a generic usb volume in [add new hardware] found in the control panel.Get xp on pirate!
