i have downloaded some themes from the internet and i wanted to install them on my mobilephone. i have no bluetooth or IR adapter to transfer but i have an mmc card reader in my pc. where should i plant this theme on my mmc card. because i have put it on my mmc card and i didnt find it on the theme in my mobilephone. (sorry for my bad englisch i am from germany)
thanx Martin
66600 transfer themes on my 6600 but without IR/Bluetooth
Use Fexplorer,which you can get from here free.
Then locate the .sis file in E: = (mmc)
Open it,and it should then self install. 😊
Alternatively, see if you can download the theme straight from the internet to your 6600. Of course, it depends if the website offers a mobile-friendly version to obtain its content, such as http://mobile.symbianthemes.com/.
put the sis file into any folder of your mmc(except system folders)
and u dont want fexplorer!!!
open the sis file using FILE MANAGER and ur done 😉
ok Thx to all of you i had tried the way jojo explained. and it works.
cu Bibo
elton wrote:Use Fexplorer,which you can get from here free.Then locate the .sis file in E: = (mmc)
SAY ELTON aren't you afraid that mango will sue you cos u have used an picture they use in an theme?
