hi,
I have the 7610. I also have an hs-2r headset which uses the pop-port for connection. I understand that 7610 is mono and hence the headset should not work. However, is there a way i can use the headset for listening to mono sound from the phone, lets say by software downloads ? I guess as the phone and the headset use the same port, it might be possible. This way i get to use the fm radio on board the hs-2r as well.
thanks
dipesh
