Hi all,
this is my 1st foray to symbian, having used tungsten W, treo 600, and (currently) mpx 200.
I wonder whether the 9500 can sync the notes in Outlook express, and if not whether there is a software I can purchase to do that?
And is there any bible software for 9500?
thanks
Notes & Bible for Nokia 9500
No notes sync I'm afraid.
You can search for bibles here. But be sure to download the Mobipocket Reader for Series 80 first.
Btw, welcome to the forum. 😊
I have tried downloading Mobipocket Reader with no success. The instructions speak of "synchronizing with the PDA". How on earth do you do that? The PC suite only allows you to synchronize with Outlook, or Lotus or the like. I tried the "send to the PDA" option from my PC, and although they appear in the Nokia, they wont install. Am I missing out on something?
@elkmajor
For the 9500 PC Suite Mobipocket cannot transfer files from the PC Mobipocket. You need to download the files to the 9500 using Opera on the 9500 or could try to copy them directly via the File Manager of PC Suite. I have tried the former and it works okay.
Thanks. It works.
