I'm glad to report I found a workaround to import contacts from Mac Address Book on the 9500. Not that difficult, when you know how.... 😉)
There's a Symbianware utility for 9210 - SmartVcard - that allows to import contacts from a Vcard file: I tried it and it works fine on the 9500 also.
All you Mac users need to do is export all the contacts in Vcard format (2.1 or 3.0 - it doesn't matter) and import it with SmartVcard.
A couple of things to remember:
- don't send the vCard file via Bluetooth: the 9500 reads it as a single contact and imports just the first one on the list; you have to copy it on a MMC with a Card reader.
- for reason beyond understanding SmartVcard does not recognize the vCard file if it's still on the card, so before importing it you have to copy it on the C: disk.
I'm not going to buy the app until Simbianware releases a 9500 version, but when they do I'll be the first in line 😊).
Hope this helps other Mac users.
Peace
P.
