Sony Ericsson Desktop for P910 released
5 replies · 8,308 views · Started 04 December 2004
I must say that it doesn't FULLY work on the P900. Tried and tested. Not only by myself but others as well.
That is correct! It won't autostart on flip open, but that's the only thing I found not working on the P900...
Delta737 wrote:That is correct! It won't autostart on flip open, but that's the only thing I found not working on the P900...
I try your program on my new P910i and it give a good effect .... but i want to delete it on my phone.
What's the procedure :icon1: to delete this program and reinitialise my phone as before setting up. :con?
Thank you for your help.
Best regards,
It's not really "my" program, I just gave the link.
Anyway to delete apps, you have to go to the control panel --> Third tab called "General" (in my case that is) --> Memory management (may be called different, I have a Dutch version) --> Then click "Delete" or "Remove" (once again don't know exact translation). There you'll see all the apps installed on your phone, including SE Desktop, which can be deleted from there
