HELP! i think im violated with my 7650 software maker
8 replies · 3,450 views · Started 15 October 2002
i installed ximplify seleq on my phone, i know its a shareware and it will be fully functional within 14 days then i should register it, what if i dont want to use, i uninstalled right away i installed it, because it cost too much for me. then i realize that i want to use it for other purpose, when i tried to installed the seleq after 14 days, it expired, and still it recognize that you've installed the software even you don't use it. does anyone know where the seleq registered on the 7650??? (just like on windows u can delete registry when you want to clean it up, you just simply run regedit.exe) cause... maybe there are some malicious files that being installed on my phone that i dont know where the "software maker" installed there files... the clock is running even you don't use it. can anyone know how to find it??? i think we have the rights to know where they put there files on our phone. in the first place its our phone right???
I have face same problem too. I believe it's not within the registry, coz i install other file management appl ( eFileManager ) and try to see is there any hidden files kept inside c: or d: drives. To my finding... there's nothing, even i check the backup files in my pc also show the same thing.
It's the intelliengene of this appl 😃 well done to ximplify. There is one way to turn around this problem... buy it 😉 nothing is free for a super good appl 😉
yes that's true! i could not found any trace where ximplify put there hidden "code". if there someone know... pls let us know... 😃
i havent a credit card to buy one... and for me its cost too much. and now... its $18
Why not trying the latest update SeleQ1.2i.
The trial period is always renewed for update & you can always using the trial 14 days trial without buying it because they seem to update their sofware quite frequently.
If nobody buys their software then there is no meaning in actually updating it! I say if you use it buy it! Thats the only fair solution! But then again thats just me! 😊
For those willing to use Seleq within the trial period, you can reset your phone and reinstall seleq.
Best reseting tool would be System tools.
But if you like the software then buy it.
cizake
Dont understand why someone can afford an expensive phone like the 7650 but not some bucks for one of the best software for it
[quote="Freddie666"]Dont understand why someone can afford an expensive phone like the 7650 but not some bucks for one of the best software for it[/quote]
good say,funny how peopel are...
some bucks for a helpful prog.like this is nothing...
unbelivebale :roll:
the swiss guy
Maybe they dont have a c/card and have no way of actually getting the money to distributor to buy it...
Maybe they dont believe in paying anything over double digits for a 4bit application on a mobile phone.....
Maybe in their country of Origin, they have a very poor Exchange rate, so where is only $20 to buy in US, with their exchange rate it becomes mor elike $45
Would you pay $45 for a piece of software for a phone?
and no not all these reasons apply to myself, im just giving you the other side of the coin.
