I used gnubox to be able to play N-Gage games in the Arena using Bluetooth, but it seems to have messed up the sending of SMS messages.
Can anyone help?
Can anyone help?
when u open up gnubox just go to options>1box phone
that should fix the problem
This is sort-of-a bug in gnubox. When it changes the configuration of the default modem, it changes not only the data modem used for dial-up connections, but also the ModemForPhoneServicesAndSms.
Gnubox can be patched to change only the data modem and not the sms one. I have already done this on sonyericsson version of gnubox. Hopefully it will be back-ported to series60 sometimes. (you can watch the forum http://www.symbianos.org/yabbse/index.php?board=2;action=display;threadid=7
or go to http://xan.dnsalias.org/gnubox to read more or fetch the sources and try to merge it into gnubox for s60)
