ei, brahs!
when u go to settings/security/certif. management u will see a lot of different certificates. my question is, is it safe to delete these certificates? and if i do, will it save me memory?
thanks for ur answers in advance.
ei, brahs!
I must say that I think I never used certificates, but it wont help you much if you delete them... too small to make a difference i think.
Yes I agree, and the Security/Kb trade-off is not worth it!
thanks for the quick response, i was just wondering if those certificates are part of the documents. i see a big bulk of my memory gone to documents (when i do a memory scan) - i dont thinks its because of my messages bec my inbox and other personal folders are empty all the time, and also my sent folder only saves 5 messages. what do u think then accounts for these documents? my memory says about 400kb is used by it alone.
thanks again!
