Steve Litchfield's Review
7 replies · 4,124 views · Started 06 December 2004
I've just read Steve's sobering review. OK, I need to know how or what to do about Notes. Is there no replacement whatsoever? Yes I am one of the few that use it and I don't know what I'd do without it. It is in fact the only reason so far that I know of not switching to the 9500
Can you post a link of the review?
David
(It's too late, I've ordered mine and waiting!)
Tahir wrote:I've just read Steve's sobering review. OK, I need to know how or what to do about Notes. Is there no replacement whatsoever? Yes I am one of the few that use it and I don't know what I'd do without it. It is in fact the only reason so far that I know of not switching to the 9500
Hello Tahir,
You can use Notes ( notes.sis) on the 9500 if:
1. you don't mind limiting yourselve to keyboard shortcuts.
2. You learn to assign new notesfiles to the folder of your wishes (File manager/find the notes document you made.../file/add to desk). You have to do this only once for each new file.
Not to be confused with the "new note" button from within the program; also that works fine.
If , e.g. you want to change the preferences, use ctrl K and change e.g. the width of the screens
All no problem at all. Use ctrl S to save, or just use the close button and all will save OK.
I use it now for a week as also I could not do without. It works great, even printing to my WIFI network HP 1010
It even supports the rocker key, which cannot be said of my second addiction:cards.sis.
Did you know by the way (of course you did) that you can go up and down in the left screen with ctrl arrow up/down key?
Succes, it is a great app!
Huib
So notes.sis comes with the 9500 or do we install it ourselves from the 9210i package. Just in case it's the latter, I"m sure I don't have notes.sis, can anyone tell me where I can get it from?
Guys,
Will notes.sis synch with Outlook (2003)? If I remember correctly, it did synch notes on the Revo..?!
