Finally found someone who makes a screen protector for the Nokia 9500. I've spent a small fortune on it and I'm getting it protected before it gets scratched. The screen protector can be found here,
http://www.overlayplus.com/dis_product.asp?prod_type=screen&model=nokia_9500&modeln=%20Nokia%209500%20communicator
Nokia 9500 screen protector
Personally, I'm not going to bother. It will be protected when the phone is shut which is the most likely times for damage.
I'm not going to buy it either - didn't use one with the Palm and the P900, don't think I'm gonna need it now that I'm using a machine with no touchscreen....
Just my US$ 0,02, of course.
Peace
P.
It smells like an advert 😉
Same here, I don't think i'll use one either, I mean with a palm device and the stylus most of the time on it I couldnt think of not using one.
Now maybe a screen protector on the small phone part wouldn't be such a bad idea, seeing how it is going to be exposed to the outside. Ill just cut some of my old CLie UX50's or NZ90 ones to size when needed. 😃
