Activesync 9500 to MS Exchange Server 2003
6 replies · 8,903 views · Started 06 December 2004
Hello,
Is there a way (or product) to Sync a 9500 to MS Exchange Server 2003 using either the OMA or Activesync features?
Thanks,
BIGmate
I don't have a 9500 yet, might anyway "only" get a 9300 😃 , but check this:
Go to Desk -> Tools -> Synchronisation
Synchronisation is via bluetooth, IR or cable connection directly with your PC.
If you would like to do it over GPRS, then you should check e.g. www.mightyphone.com This will provide you with a trial for a week, but I'm not sure if they already support the 9500.
I have a 9500 but I don't have a Windows desktop, so I can't Sync to a PC to get mail and calendar info that way. My old Palm Treo 650 had a mail client called Versamail that could sync directly with the Exchange server via webmail (activesync). I noticed that Nokia evidently licensed ActiveSync in March of 2005, but no one's seen a client yet?
