Nokia 9500 resetting problems
3 replies · 3,955 views · Started 06 December 2004
Hello
I am experiencing problems with my Nokia 9500 not clearing it's memory.
The device will appear to have cleared it's memory but if the battery is removed and then re-attached the previously cleared/deleted content will reappear.
I have attempted a rebooting of the device but content will return when rebooting has completed.
Does anyone know of a way of resolving this problem without reflashing the device?
lippythelog wrote:Hello
install reboot software . no more remove battery
reboot software? is that 'restart software'? can you send the links, also whats the name of the software. thanks
