Hi just got my A1000.
Wich folder on my C:-drive contains the ringtones?
I've downloaded some mp3's toit but they don't show up on my ringtones menu.
well you are right, for some reason the ringtone files are hidden. however, to install a new one, you can follow the procedure that Nakazul suggested on the thread I submitted (unwanted sounds). it works
There are two ways:
1. Copy the new ringtones directly into the C:\documents\Ringtone\ folder (they can be used as ringtones immediately) OR
2. Copy them into the C:\documents\media files\audio\unfiled folder and they will be available to the audio program. Then open the ringtune manager in the control panel and install them.
Cheers,
Dave
