Dear Sirs, the users of eFileManager want more features!!! Look SeleQ from Ximplify!!! A lot of features and an OK price!!! Please work hard to give us at least the same features that SeleQ!!! Be competitive!!!
To PSI NT
Why buy eFileManager when you can buy SeleQ???
If they're going to be competitive, they're going to have to do better than copy the features of SeleQ. New, innovative features are required.
Example: An integrated web-browser (that's HTTP, not WAP). 😉
I dont really think that efilemanager should include a web broswer since it a completely different piece of software and its primary use it for file browsing! I think seleQ is the best software for this but its true that efilemanager is way behind!
i have also a question to psiNT:
The e-profile-Beta-prof-version is real nice,
and work good,if the user all the old alarm settings first remove.
(Handy-clock from epocware/world-clock also)
I really like the progy:its at least only around 100 kb
and supports the different alarmtones-settings also without worldclock.
The different backgrounds,the easy way to timed-chanche-profiles:
and its not anymore bugy 😉
But if i wanna enter to register,ive got a Kernel.ecel 3-error.
and thats it.
(i already do not buy a key from u,
but i was so much confused,
cause if i move the date of phone 2-3jears furder,the progy still works out.
(also world-clock prof./task-manager)
that i tried to enter to find out,what for a funny trial this is.)
So here is my question:
What is then the differents between the trial and the full-version???
Has the full more features,or has it less kb??
cause i want soonly buy e-profile/taskmanager from u out there...
i say thanX in advance for a fastly anwer...
best regards S�mi
Sound Great.
I will try it .
PsiLoc always produce great application.
Below are my favourite:
a. TaskMan
b. eProfile (I give it 5 stars)
c. system tool
d. Efilemanager(latest update will include advance search 😃 )
e. Work clock Pro (I think it is better than Handy Clock.)
PsiLoc simply the Best Symbian Developer.
MaleBuffy, I sort of agree with you there, because I think a web browser should have been part of the operating system in the first place. I would think the only reason why it's not, is that doing this would initiate the death of WAP.
Hello,
To Manowar:
New version of File Manager will be available shortly (within week or two).
Some of new features: simple & advanced search functions, "open with", functions to clean up disk etc.
Remember that all our products are designed to be as smart/compact as possible, File Manager will never contain web browser, key lock, task switching etc.
To Sami:
Trial versions of our products are fully functional (only time limited).
But beta versions may not contain all functions planned for final release, may be slighty larger (due to some test code inside) etc.
About Extended Profiles Professional: we are looking for yours opinion, what else we can add to this application...
PsiNT
Thank u for the fast answer:
i would like only to get new one thing:
if i open e-profile,i would like that the Joystick not open the edit of the profiles(what the left softkey already could do)
Better activat withit the profile.
Cause there are some users like me out there,they dont wanna kill the start-stop-key with changing profiles.
(I have e-profile already in the favorites:
with this app.u made the phone 100%better)
so we could activate the profiles also inside your app as fast as in the original-profiles.
(I know,that it is not really necessairy,but why not?)
I found only one small bug:
if the app open a alarm/Calendar-ton,it peep ones,and then after the ton starts to sound.
(But maybe this is now bug and the phone is not fast enough to put the sound?
But otherways this prog look allright.
-world-clock-pro.(the newest Version)
dont work allways really clear with it:somethimes there are the wishes sounds,somethimes not.
also if he work allone in phone it have this bug.
-screensaver many bugs seems to fix out,the Kernel-error is gone,
and it seems to work good.
But the big analog-clock shows allways the same time.
if u hide the SC and then he comes back,it shows new the right time,but allwas the same for hours.
(I was not really test him out,but a friend of mine have him from the first betas until now and tell me the newest bugs he find out.)
But i dont understand something:
if u say,the trials have 21days,why i can use world-clock-prof./E-profile also in the "year 2005"??
(i put the Date of phone further intoo the future)
Is this,because they are all betas?
or because your progys change trial-days only in realtime?
and what is with the new Version of task-manager?
I load him until aug. allways only up to put new favorits,but i would maybe like to have him for allways on the phone.
The Joystick-setting-to an�app.is great:but how bugy?
i ask,because i test hard out different prog. (for epocware),
but i�m only a poor guy out there,and will have no money too remove a new 7650 if something really bad happen to my phone.
(What allready was happen bevor some days crash down my Sms/Mms/mail-app.,but i could new fix out with anold backup:
ooooh lucky guy i was)
i would be happy to stay in contact
best regards
a end-user:
S�mi
Well Psiloc, thank you for your answer and keep your good work 😉
[quote="psiloc"]
PsiNT[/quote]
FIRST OF ALL REPLY TO YOUR CUSTOMERS THAT HAVE PROBLEMS AND PAY FOR YOUR APPLICATIONS :evil:
