Here there anybody who know if we can make safeties from the 9500 to a Mac and with which programm.
In Bluetooth my Powerbook G4 17inches says that he cannot Valid the phone???
Can you hemp me on these 2 points.
Thank you in advance;
Didier
Didier
Apple's iSync doesn't yet support the newer Nokia Symbian operating system based phones. You should be able to send items (files, contacts, etc.) one by one over Bluetooth between the devices, though.
Or you can use the program Nokia Collector ( http://www.nokia.com/nokia/0,,67269,00.html ) which will allow you to send several files directly to your 9500 without using the send by bluetooth function of Mac OSX
I think that if Nokia does want to work a little bit more on it , Nokia collector would be just better on Mac than PC suite for pc
