If I use for example x^2 instead SQR(x) it tells error.
I need for example x^50, how can I write it (exists some function etc..)? I cann't find anything in WIKI.
btw similar problem I have with for example 10th extraction...
thanks
thanks
Perhaps something like this? Everyone should know how to do this...
n^x:
proc power%😞n%,x%)
local z%,i%
i%=1
z%=1
IF x%=0
return 1
endif
do
z%=z%*n%
until i%>x%
return z%
endp
This was written thinking fast and without testing...
Ok,.... But what about extraction (or root?). I think it cann't be done like this example above....
Just use :
x**n
where n is a real number and x is a positive real number. So you can apply it to solve your problems :
x**50
x**(1/10)
Regards, Roberto
Thx, x**n is running good, but if I use x**(1/n) it constantly write only "1".
For example:
PROC pow:
PRINT 1000**(1/3) REM It should be 10, but it is 1
GET
ENDP
Try to use convert the power to a real number, for example :
PROC pow:
PRINT 1000**(1./3) REM It is 10 as expected.
GET
ENDP
I was not aware about this detail...
hehe, you're right Roberto. I don't know why, but the "." does a lot.. 😉
