Problems with Agilemessenger
4 replies · 2,262 views · Started 08 December 2004
Hello,
I have search the forum to see if there were any similar problems, but couldn't find any. I can send and receive TEXT messages on Agilemessenger; however, can not send voice (push to talk) or pictures. I was able to do this a couple weeks ago, but now it does not work. I tried a soft-reset and it still is not working. Tried reinstalling Agilemessenger (no worky). I checked my GPRS/access point settings and it all looks fine (as it did before). I am using Tmobile Tzones and a Nokia 3620. Agilemessenger is a pain in the butt when you don't have the push-to-talk feature! Thanks for any help you all can provide.
Bill
PS. I have lost my wap browsing too (will connect to access point, but times out on any wap page). Assuming it is the same problem.
Has any one had a problem like this? I talked to Tmobile and they are telling me it is the phone. One thing I forgot to mention, two weeks ago I kept getting a "startup app failed" error when the phone started up. This disabled my menu button (couldn't do anything but, use it as a phone). So, I reset the phone (which fixed the startup app/menu problem... but now my browser and PTT voice on agilemessenger doesn't work).
Thanks for your help,
Bill
So, I contacted nokia technical support and they have concluded that the phone has reverted back to a partial "locked" state (originally an ATT phone before being unlocked and used for tmob). Is this possible (it may have happened during one of the hard resets I did)? I was under the impression that the unlock is flashed onto the phone (no reset can reflash a phone, right?).
At anyrate, I give up. Take care, folks!
Bill
WhiskeyTangoFox wrote:So, I contacted nokia technical support and they have concluded that the phone has reverted back to a partial "locked" state (originally an ATT phone before being unlocked and used for tmob). Is this possible (it may have happened during one of the hard resets I did)? I was under the impression that the unlock is flashed onto the phone (no reset can reflash a phone, right?).
Bill
It can! Most of the operator software is ROM, then one total reset, can return well to the original state. But the solution is easy, to unblock of new.
