I have a dream: 3650 features on 7650
11 replies · 3,865 views · Started 15 October 2002
7650 and 3650 both are running on a 32-bit RISC CPU based on ARM-9 series with Symbian OS v6.1 operating system.
so theoretically it would be possible to add a MMC-port to 7650?!
(besides the question about enough space in the handsets underframe... )
but looking at the solution at the 3650 I must say that the MMC-part is pretty small:
and don�t we all want bluetooth-heaset and car-profile, wap 2.0, trialband and chtml-browser with java on our 7650�s?! :P
and what about the FM-radio from 8310? or the "pop-port"(USB?)-interface from the 7210?
I want it all !!! and I want it know on my 7650 and not in the middle of 2003 on a delayed launched, too large and ugly 3650 with first buggy firmware, a camera-lense without any protection, an ideotic oval keypad with bad to handle joystick.
so what do you think? could that all be built in a 7650 from a 3650?!?
what must be done on the sw- and hw-side to get such a phone running?
I say dream on 😃
Well its the problem is not the software side its the hardware side! If you are really serious about it then i have some pointers for you! In order to add a MMC slot there must be some serious changes inside the phone! Firmware should support these changes and its virtually impossible.
The other things you talked about like, BT Audio etc which is actually software can be done and maybe done by Nokia at some point! But I dont think than an MMC slot add-on is possible!
Better wait for a newer 76xx model! 😊
We all want a phone that does everything but you'll be waiting forever for it.
If your a big company like Nokia, what's the point in having one phone that can do everything? Your other models wouldn't sell.
At some Nokia will make a phone that does all of the above and more, but by then there will be other Nokia models that do better things.
That's just the way it is. :cry:
Yeah we'd all like it all but i would personally just settle for more memory on the damn thing !
Oh yeah and a CTRL / ALT / DEL Key ...
Seems if a few ppls phones have crashed on full memory or what ever mine has failed on that some counter measure would be built in to stop over loading the memory usage ! My 2 cents anyhow !
some says that the BT audio profile is the hardware issue
cos nokia said the the chip for the BT is the problem
but i dunno if it;s the software issue
Nokia said that the BT chip is the problem? Where? You you put a link here?
Becasue I read that Nokia said that it is a software problem!
[quote="OsirisMedia"]ahh nOkia jsut tell ya whatevewr they feel like at the time.[/quote]
MaleBuffy is right, the BT audio is only software that you have to download, not hardware.
I'm from Nokia if that matters
I think he means download to your phone! I dont believe that there is a BT audio aplpication on the internet 😊
It says in the Manual, that you can "see" the headset in your phone, but you can't use it.
